Ga door naar hoofdinhoud
LG Stylo 2 Plus Rear Camera Replacement
Wat je nodig hebt
  1. LG Stylo 2 Plus Rear Camera Replacement, Rear Case: stap 1, afbeelding 1 van 3 LG Stylo 2 Plus Rear Camera Replacement, Rear Case: stap 1, afbeelding 2 van 3 LG Stylo 2 Plus Rear Camera Replacement, Rear Case: stap 1, afbeelding 3 van 3
    • To remove the rear case of the phone, insert the spudger into the opening on the back of the case.
    • With the spudger parallel to the frame of the phone, slide it along the edge, forcing the casing to pop off.
  2. LG Stylo 2 Plus Rear Camera Replacement, Battery: stap 2, afbeelding 1 van 3 LG Stylo 2 Plus Rear Camera Replacement, Battery: stap 2, afbeelding 2 van 3 LG Stylo 2 Plus Rear Camera Replacement, Battery: stap 2, afbeelding 3 van 3
    • To remove the battery, insert your fingernail or the flat end of the spudger into the dimple at the bottom of the battery and lift upwards.
    • Firmly grasp the battery and remove from the phone.
  3. LG Stylo 2 Plus Rear Camera Replacement, Mid-Frame: stap 3, afbeelding 1 van 2 LG Stylo 2 Plus Rear Camera Replacement, Mid-Frame: stap 3, afbeelding 2 van 2
    • Using the JIS #000 screwdriver, remove the eleven 4mm screws around the mid-frame.
  4. LG Stylo 2 Plus Rear Camera Replacement: stap 4, afbeelding 1 van 2 LG Stylo 2 Plus Rear Camera Replacement: stap 4, afbeelding 2 van 2
    • Insert the metal spudger in the dimple at the base of the cover.
    • Pry upward, removing the mid-frame from the phone.
  5. LG Stylo 2 Plus Rear Camera Replacement, Rear Camera: stap 5, afbeelding 1 van 3 LG Stylo 2 Plus Rear Camera Replacement, Rear Camera: stap 5, afbeelding 2 van 3 LG Stylo 2 Plus Rear Camera Replacement, Rear Camera: stap 5, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Flip the cover over to show the rear camera unit in the center of the cover.
    • Using the tweezers, carefully grab the rear camera unit and pull directly upward, removing the unit from the cover housing.
Conclusie
Noah Kehm
241 Reputatie
3 handleidingen geschreven
UW Tacoma, Team S1-G3, Cardinal Spring 2019 Lid van UW Tacoma, Team S1-G3, Cardinal Spring 2019
UWT-CARDINAL-S19S1G3
4 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 105
