Inleiding
If you need to replace the front facing camera of your LG Stylo 2 Plus, follow this guide. When the phone is unable to capture photographs due to damage a replacement will be necessary. This an intermediate task that will involve handling small, delicate parts of the device (e.g. ribbon cable).
Wat je nodig hebt
To remove the rear case of the phone, insert the spudger into the opening on the back of the case.
With the spudger parallel to the frame of the phone, slide it along the edge, forcing the casing to pop off.
To remove the battery, insert your fingernail or the flat end of the spudger into the dimple at the bottom of the battery and lift upwards.
Firmly grasp the battery and remove from the phone.
Using the JIS #000 screwdriver, remove the eleven 4mm screws around the mid-frame.
Using a pair of tweezers, carefully detach the ribbon cable connecting the camera to the motherboard.
Still using the tweezers, firmly pull up to remove the camera from the phone.
