Ga door naar hoofdinhoud
LG Stylo 2 Plus Battery Replacement
Wat je nodig hebt
  1. LG Stylo 2 Plus Battery Replacement, Rear Case: stap 1, afbeelding 1 van 3 LG Stylo 2 Plus Battery Replacement, Rear Case: stap 1, afbeelding 2 van 3 LG Stylo 2 Plus Battery Replacement, Rear Case: stap 1, afbeelding 3 van 3
    • To remove the rear case of the phone, insert the spudger into the opening on the back of the case.
    • With the spudger parallel to the frame of the phone, slide it along the edge, forcing the casing to pop off.
  2. LG Stylo 2 Plus Battery Replacement, Battery: stap 2, afbeelding 1 van 3 LG Stylo 2 Plus Battery Replacement, Battery: stap 2, afbeelding 2 van 3 LG Stylo 2 Plus Battery Replacement, Battery: stap 2, afbeelding 3 van 3
    • To remove the battery, insert your fingernail or the flat end of the spudger into the dimple at the bottom of the battery and lift upwards.
    • Firmly grasp the battery and remove from the phone.
Conclusie
Please dispose of the old battery properly by bringing it to a electronics recycling facility or calling the phone number on the back for more instructions.
Noah Kehm
241 Reputatie
3 handleidingen geschreven
UW Tacoma, Team S1-G3, Cardinal Spring 2019 Lid van UW Tacoma, Team S1-G3, Cardinal Spring 2019
UWT-CARDINAL-S19S1G3
4 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 852
