Ga door naar hoofdinhoud
LG Spectrum Sim/SD Port Replacement
Wat je nodig hebt
  1. LG Spectrum Sim/SD Port Replacement, Battery: stap 1, afbeelding 1 van 2 LG Spectrum Sim/SD Port Replacement, Battery: stap 1, afbeelding 2 van 2
    • Using your thumbnail, lift up on the notch in the middle of the bottom side of the phone.
  2. LG Spectrum Sim/SD Port Replacement: stap 2, afbeelding 1 van 1
    • Using either your thumbnail or a plastic opening tool, lift up on the battery using the notch in the bottom left hand corner of the battery and remove it from the phone.
  3. LG Spectrum Sim/SD Port Replacement, Sim/SD Port: stap 3, afbeelding 1 van 2 LG Spectrum Sim/SD Port Replacement, Sim/SD Port: stap 3, afbeelding 2 van 2
    • Remove eleven 4mm Phillips #000 screws with a PH000 screwdriver.
    • Use the magnetic mat to keep the screws in one place.
  4. LG Spectrum Sim/SD Port Replacement: stap 4, afbeelding 1 van 1
    • Use the plastic opening tool to firmly pry up the plastic backing around the perimeter of the phone.
  5. LG Spectrum Sim/SD Port Replacement: stap 5, afbeelding 1 van 1
    • Detach the black rectangular film attached to the SIM/SD card plate with a plastic opening tool.
  6. LG Spectrum Sim/SD Port Replacement: stap 6, afbeelding 1 van 1
    • Hook the plastic opening tool underneath the plate and gently lift it up.
  7. LG Spectrum Sim/SD Port Replacement: stap 7, afbeelding 1 van 1
    • Gently wiggle the plate side-to-side while pulling up to release it from the metal clamps holding it in.
Conclusie
Aiman Sallam
506 Reputatie
5 handleidingen geschreven
USF Tampa, Team 1-4, Sullivan Spring 2016 Lid van USF Tampa, Team 1-4, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G4
3 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 28
Altijd: 379
