Ga door naar hoofdinhoud
LG Risio Rear-Facing Camera Replacement
Wat je nodig hebt
  1. LG Risio Rear-Facing Camera Replacement, Back Panel: stap 1, afbeelding 1 van 2 LG Risio Rear-Facing Camera Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Use a plastic opening tool to seperate the back panel from the device.
    • Remove the back panel.
  2. LG Risio Rear-Facing Camera Replacement, Battery: stap 2, afbeelding 1 van 1
    • Place your thumb along the bottom of the battery and pry upwards to remove.
  3. LG Risio Rear-Facing Camera Replacement, Midframe: stap 3, afbeelding 1 van 1
    • Press down on the SIM eject tab with a fingernail (or iFixit opening tool), and slide the SIM card out.
  4. LG Risio Rear-Facing Camera Replacement: stap 4, afbeelding 1 van 2 LG Risio Rear-Facing Camera Replacement: stap 4, afbeelding 2 van 2
    • Remove the eight Phillips #0 screws from the internal support frame.
  5. LG Risio Rear-Facing Camera Replacement: stap 5, afbeelding 1 van 3 LG Risio Rear-Facing Camera Replacement: stap 5, afbeelding 2 van 3 LG Risio Rear-Facing Camera Replacement: stap 5, afbeelding 3 van 3
    • Use an opening tool on the marked locations to lift the edges up. There should be a small click when lifting these edges up.
  6. LG Risio Rear-Facing Camera Replacement: stap 6, afbeelding 1 van 1
    • Using your hand, pick up the midframe to separate it from the phone.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 14
Altijd: 129
