Ga door naar hoofdinhoud
LG Risio Motherboard Replacement
Wat je nodig hebt
  1. LG Risio Motherboard Replacement, Back Panel: stap 1, afbeelding 1 van 2 LG Risio Motherboard Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Use a plastic opening tool to seperate the back panel from the device.
    • Remove the back panel.
  2. LG Risio Motherboard Replacement, Battery: stap 2, afbeelding 1 van 1
    • Place your thumb along the bottom of the battery and pry upwards to remove.
  3. LG Risio Motherboard Replacement, Midframe: stap 3, afbeelding 1 van 1
    • Press down on the SIM eject tab with a fingernail (or iFixit opening tool), and slide the SIM card out.
  4. LG Risio Motherboard Replacement: stap 4, afbeelding 1 van 2 LG Risio Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Remove the eight Phillips #0 screws from the internal support frame.
  5. LG Risio Motherboard Replacement: stap 5, afbeelding 1 van 3 LG Risio Motherboard Replacement: stap 5, afbeelding 2 van 3 LG Risio Motherboard Replacement: stap 5, afbeelding 3 van 3
    • Use an opening tool on the marked locations to lift the edges up. There should be a small click when lifting these edges up.
  6. LG Risio Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Using your hand, pick up the midframe to separate it from the phone.
  7. LG Risio Motherboard Replacement, Motherboard: stap 7, afbeelding 1 van 2 LG Risio Motherboard Replacement, Motherboard: stap 7, afbeelding 2 van 2
    • Detach the screen connector from the motherboard by putting your thumb underneath it and lifting up.
    • The screen connector is the part that has P5 written on it.
  8. LG Risio Motherboard Replacement: stap 8, afbeelding 1 van 1
    • On the side with the screen connector, pull the two tabs away from the device.
    • Use the plastic opening tool to lift the motherboard starting on the bottom right corner and pulling upwards.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 261
