Ga door naar hoofdinhoud
LG Rebel Rear Camera Replacement
Wat je nodig hebt
  1. LG Rebel Rear Camera Replacement, Rear Camera: stap 1, afbeelding 1 van 2 LG Rebel Rear Camera Replacement, Rear Camera: stap 1, afbeelding 2 van 2
    • Turn the phone on its side and locate the small groove.
    • Use the plastic opening tool to take the back cover off of the phone.
  2. LG Rebel Rear Camera Replacement: stap 2, afbeelding 1 van 3 LG Rebel Rear Camera Replacement: stap 2, afbeelding 2 van 3 LG Rebel Rear Camera Replacement: stap 2, afbeelding 3 van 3
    • Locate the small groove on the back of the phone near the bottom.
    • Use the metal spudger to pop open the black plastic covering.
    • Remove black plastic covering.
  3. LG Rebel Rear Camera Replacement: stap 3, afbeelding 1 van 2 LG Rebel Rear Camera Replacement: stap 3, afbeelding 2 van 2
    • Use the metal spudger to pop up the black plastic covering near top of phone.
    • Remove the black plastic covering.
  4. LG Rebel Rear Camera Replacement: stap 4, afbeelding 1 van 3 LG Rebel Rear Camera Replacement: stap 4, afbeelding 2 van 3 LG Rebel Rear Camera Replacement: stap 4, afbeelding 3 van 3
    • Locate the connective pieces on the back of the phone.
    • Use the metal spudger to disconnect both of the connective pieces from the back.
  5. LG Rebel Rear Camera Replacement: stap 5, afbeelding 1 van 3 LG Rebel Rear Camera Replacement: stap 5, afbeelding 2 van 3 LG Rebel Rear Camera Replacement: stap 5, afbeelding 3 van 3
    • Flip the phone over so the screen is facing up.
    • Slide the metal spudger around the perimeter of the phone until the entire seal has been broken.
    • Use the small suction cup to remove the screen.
  6. LG Rebel Rear Camera Replacement: stap 6, afbeelding 1 van 2 LG Rebel Rear Camera Replacement: stap 6, afbeelding 2 van 2
    • Locate the black bumper at the bottom of the front of the phone.
    • Use the metal spudger to slide the bumper out.
  7. LG Rebel Rear Camera Replacement: stap 7, afbeelding 1 van 3 LG Rebel Rear Camera Replacement: stap 7, afbeelding 2 van 3 LG Rebel Rear Camera Replacement: stap 7, afbeelding 3 van 3
    • Use the metal spudger to carefully loosen the motherboard from the body of the phone.
    • Slowly slide the motherboard out of the body of the phone.
    • Remove the motherboard.
  8. LG Rebel Rear Camera Replacement: stap 8, afbeelding 1 van 2 LG Rebel Rear Camera Replacement: stap 8, afbeelding 2 van 2
    • Locate the rear camera on the motherboard.
    • Use the metal spudger to disconnect the connective piece at the base of the camera.
    • Remove the camera.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Emma Johnson
184 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 13
Altijd: 672
