Ga door naar hoofdinhoud
LG Rebel Front Camera Replacement
Wat je nodig hebt
  1. LG Rebel Front Camera Replacement, Front Camera: stap 1, afbeelding 1 van 3 LG Rebel Front Camera Replacement, Front Camera: stap 1, afbeelding 2 van 3 LG Rebel Front Camera Replacement, Front Camera: stap 1, afbeelding 3 van 3
    • Turn phone over to its front side.
    • Use a spudger to begin removing the screen by the right hand corner. Begin to move the tool around the edges of the screen.
  2. LG Rebel Front Camera Replacement: stap 2, afbeelding 1 van 3 LG Rebel Front Camera Replacement: stap 2, afbeelding 2 van 3 LG Rebel Front Camera Replacement: stap 2, afbeelding 3 van 3
    • Once you have loosened the grip around the edges, pop off the screen using a suction cup.
    • Once the front screen is removed, place the phone on its side and find the groove located on the side.
    • Use the plastic opening tool to pop open the black plastic covering.
    • Remove black plastic cover.
  3. LG Rebel Front Camera Replacement: stap 3, afbeelding 1 van 3 LG Rebel Front Camera Replacement: stap 3, afbeelding 2 van 3 LG Rebel Front Camera Replacement: stap 3, afbeelding 3 van 3
    • Locate the small groove on the back of the phone near the bottom.
    • Use the metal spudger to pop open the black plastic covering.
    • Remove black plastic covering.
  4. LG Rebel Front Camera Replacement: stap 4, afbeelding 1 van 2 LG Rebel Front Camera Replacement: stap 4, afbeelding 2 van 2
    • Use the metal spudger to pop up the black plastic covering near top of phone.
    • Remove the black plastic covering.
  5. LG Rebel Front Camera Replacement: stap 5, afbeelding 1 van 3 LG Rebel Front Camera Replacement: stap 5, afbeelding 2 van 3 LG Rebel Front Camera Replacement: stap 5, afbeelding 3 van 3
    • Remove the motherboard with a spudger.
    • Slowly begin to lift motherboard with your hand carefully.
    • Once the motherboard is completely off, set the phone to the side and focus on the small black box with a square tail (which is the front camera).
  6. LG Rebel Front Camera Replacement: stap 6, afbeelding 1 van 2 LG Rebel Front Camera Replacement: stap 6, afbeelding 2 van 2
    • Remove the front camera by its tail with a spudger.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Lesley Sigaran
145 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 378
