Ga door naar hoofdinhoud
LG Realm Rear Facing Camera Replacement
Wat je nodig hebt
  1. LG Realm Rear Facing Camera Replacement, Battery: stap 1, afbeelding 1 van 2 LG Realm Rear Facing Camera Replacement, Battery: stap 1, afbeelding 2 van 2
    • To remove the back, insert thumbnail into MicroUSB port, and pull up to loosen back.
    • Use nail to loosen case on all four sides. Once loose, remove back case.
  2. LG Realm Rear Facing Camera Replacement: stap 2, afbeelding 1 van 1
    • Insert thumbnail into tab below battery.
    • Pull away from phone and remove.
  3. LG Realm Rear Facing Camera Replacement, Plastic Midframe: stap 3, afbeelding 1 van 2 LG Realm Rear Facing Camera Replacement, Plastic Midframe: stap 3, afbeelding 2 van 2
    • Once the back cover and battery are removed, use the Phillips #J000 screwdriver to remove all 11 screws located around the plastic midframe.
  4. LG Realm Rear Facing Camera Replacement: stap 4, afbeelding 1 van 1
    • Using the plastic opening tool, carefully pry and separate the plastic midframe from the rest of the phone.
  5. LG Realm Rear Facing Camera Replacement, Rear Facing Camera: stap 5, afbeelding 1 van 1
    • Locate the rear facing camera.
    • Using the plastic opening tool, pry apart the cable from where it connects to the phone.
  6. LG Realm Rear Facing Camera Replacement: stap 6, afbeelding 1 van 1
    • After removing the ribbon cable, the camera should be easy to remove with your fingers. Remove the rear facing camera.
Conclusie
Emily Palmer
287 Reputatie
1 Handleiding geschreven
Marist, Team 1-5, Laflen Spring 2016 Lid van Marist, Team 1-5, Laflen Spring 2016
MARS-LAFLEN-S16S1G5
2 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 300
