Ga door naar hoofdinhoud
LG Realm Front Facing Camera Replacement
Wat je nodig hebt
  1. LG Realm Front Facing Camera Replacement, Battery: stap 1, afbeelding 1 van 2 LG Realm Front Facing Camera Replacement, Battery: stap 1, afbeelding 2 van 2
    • To remove the back, insert thumbnail into MicroUSB port, and pull up to loosen back.
    • Use nail to loosen case on all four sides. Once loose, remove back case.
  2. LG Realm Front Facing Camera Replacement: stap 2, afbeelding 1 van 1
    • Insert thumbnail into tab below battery.
    • Pull away from phone and remove.
  3. LG Realm Front Facing Camera Replacement, Plastic Midframe: stap 3, afbeelding 1 van 2 LG Realm Front Facing Camera Replacement, Plastic Midframe: stap 3, afbeelding 2 van 2
    • Once the back cover and battery are removed, use the Phillips #J000 screwdriver to remove all 11 screws located around the plastic midframe.
  4. LG Realm Front Facing Camera Replacement: stap 4, afbeelding 1 van 1
    • Using the plastic opening tool, carefully pry and separate the plastic midframe from the rest of the phone.
  5. LG Realm Front Facing Camera Replacement, Front Facing Camera: stap 5, afbeelding 1 van 1
    • Locate the front facing camera in the top left hand corner of the motherboard. Using the plastic opening tool, separate the ribbon cable from the phone.
  6. LG Realm Front Facing Camera Replacement: stap 6, afbeelding 1 van 1
    • After removing this ribbon cable, you will be able to easily remove the front facing camera with your fingers.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Ryan St Martin
770 Reputatie
4 handleidingen geschreven
Marist, Team 1-5, Laflen Spring 2016 Lid van Marist, Team 1-5, Laflen Spring 2016
MARS-LAFLEN-S16S1G5
2 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 436
