Inleiding
This guide is made to help remove the SD card from your phone if you are having problems with it or need to replace it. The only real hazard involving this step is removing the back plating of your phone.
Wat je nodig hebt
Slide a plastic opening tool between the back and front panel at the bottom.
Één andere persoon heeft deze handleiding voltooid.
