Ga door naar hoofdinhoud
LG Optimus T Motherboard Replacement
Wat je nodig hebt
  1. LG Optimus T Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 3 LG Optimus T Motherboard Replacement, Motherboard: stap 1, afbeelding 2 van 3 LG Optimus T Motherboard Replacement, Motherboard: stap 1, afbeelding 3 van 3
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Using a prying device, such as a plastic opening tool, remove the phone’s back cover. At the top of the phone, there’s an indentation to put the Spudger into to pop the case off
  2. LG Optimus T Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery. There’s an indentation to the left of the camera lens to pull up on the battery with your finger
  3. LG Optimus T Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Use a J0 screwdriver to remove the six 4.5mm screws.
  4. LG Optimus T Motherboard Replacement: stap 4, afbeelding 1 van 2 LG Optimus T Motherboard Replacement: stap 4, afbeelding 2 van 2
    • You might have difficulty popping the interior case off. You may use the metal spudger here with caution if the plastic opening tool fails
    • Remove interior case. Insert the spudger into the indentations at the top, or bottom of the phone to pry off the interior case.
  5. LG Optimus T Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Pull up on connector tab
  6. LG Optimus T Motherboard Replacement: stap 6, afbeelding 1 van 2 LG Optimus T Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Remove SD card mount. Insert the plastic opening tool on the right side to pop off
  7. LG Optimus T Motherboard Replacement: stap 7, afbeelding 1 van 2 LG Optimus T Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Remove metal panel
    • There are four retaining points to insert plastic opening tool and pop off panel
  8. LG Optimus T Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Use a J0 screwdriver to remove the two 1.8mm screws from charging port. (Charging port and motherboard are connected.)
    • Remove motherboard
Conclusie
Één andere persoon heeft deze handleiding voltooid.
stacey
219 Reputatie
2 handleidingen geschreven
Ohio State, Team 1-3, Wilder Spring 2017 Lid van Ohio State, Team 1-3, Wilder Spring 2017
OSU-WILDER-S17S1G3
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 316
