Ga door naar hoofdinhoud
LG Optimus T Camera and Camera Mount Replacement
Wat je nodig hebt
  1. LG Optimus T Camera and Camera Mount Replacement, Camera: stap 1, afbeelding 1 van 2 LG Optimus T Camera and Camera Mount Replacement, Camera: stap 1, afbeelding 2 van 2
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down your device before you begin.
    • Use a plastic opening tool to remove the phone's back cover. At the top of the phone there are indentations to insert the spudger and pop the case off
  2. LG Optimus T Camera and Camera Mount Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery by pulling up on the battery using the indentation to the left of the camera lens
  3. LG Optimus T Camera and Camera Mount Replacement: stap 3, afbeelding 1 van 1
    • Use a J0 screwdriver to remove the 6 highlighted screws
  4. LG Optimus T Camera and Camera Mount Replacement: stap 4, afbeelding 1 van 2 LG Optimus T Camera and Camera Mount Replacement: stap 4, afbeelding 2 van 2
    • Remove interior case using indentations on the top and bottom to insert the spudger to pop off the interior case
    • You might have difficulty popping the interior case off. You may use the metal spudger here with caution if the plastic one fails
  5. LG Optimus T Camera and Camera Mount Replacement: stap 5, afbeelding 1 van 1
    • Unhook the connector tab
  6. LG Optimus T Camera and Camera Mount Replacement: stap 6, afbeelding 1 van 1
    • Remove SD card mount by inserting the plastic opening tool on the right side of the device to pop mount off
  7. LG Optimus T Camera and Camera Mount Replacement: stap 7, afbeelding 1 van 2 LG Optimus T Camera and Camera Mount Replacement: stap 7, afbeelding 2 van 2
    • Remove metal panel by inserting plastic opening tool into the four retaining points and remove panel
  8. LG Optimus T Camera and Camera Mount Replacement: stap 8, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • disconnect camera connector from motherboard by spudger
    • Once disconnected, remove camera using tweezers
Conclusie
stacey
219 Reputatie
2 handleidingen geschreven
Ohio State, Team 1-3, Wilder Spring 2017 Lid van Ohio State, Team 1-3, Wilder Spring 2017
OSU-WILDER-S17S1G3
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 127
