Ga door naar hoofdinhoud
LG Optimus L7 P705 SIM Card Slot Replacement
Wat je nodig hebt
  1. LG Optimus L7 P705 SIM Card Slot Replacement, Home Button: stap 1, afbeelding 1 van 2 LG Optimus L7 P705 SIM Card Slot Replacement, Home Button: stap 1, afbeelding 2 van 2
    • Insert a plastic opening tool between the seams of the device and pry the back cover away from the phone.
    • Remove the battery and SIM card.
  2. LG Optimus L7 P705 SIM Card Slot Replacement: stap 2, afbeelding 1 van 1
    • Remove the twelve screws using the Phillips 000 screwdriver.
  3. LG Optimus L7 P705 SIM Card Slot Replacement: stap 3, afbeelding 1 van 1
    • Remove bottom plate where the charger port is located.
  4. LG Optimus L7 P705 SIM Card Slot Replacement: stap 4, afbeelding 1 van 2 LG Optimus L7 P705 SIM Card Slot Replacement: stap 4, afbeelding 2 van 2
    • Insert a plastic opening tool between the seams of the device and apply some pressure to lift off the cover.
  5. LG Optimus L7 P705 SIM Card Slot Replacement: stap 5, afbeelding 1 van 1
    • Flip over to the face of the device.
    • Lift off the glass screen (display).
  6. LG Optimus L7 P705 SIM Card Slot Replacement: stap 6, afbeelding 1 van 1
    • Remove the home screen button. Replace as needed.
  7. LG Optimus L7 P705 SIM Card Slot Replacement, SIM Card Slot: stap 7, afbeelding 1 van 2 LG Optimus L7 P705 SIM Card Slot Replacement, SIM Card Slot: stap 7, afbeelding 2 van 2
    • Flip over to the back of the device
    • Using the plastic spudger, lift off the three board-to-board connectors on the left-hand side of the device.
  8. LG Optimus L7 P705 SIM Card Slot Replacement: stap 8, afbeelding 1 van 1
    • Using a plastic spudger, lift off the wire connector at the right bottom of the board.
  9. LG Optimus L7 P705 SIM Card Slot Replacement: stap 9, afbeelding 1 van 2 LG Optimus L7 P705 SIM Card Slot Replacement: stap 9, afbeelding 2 van 2
    • Detach the mount including both the SIM card and the motherboard from the device.
Conclusie
Yanxiang Ding
101 Reputatie
1 Handleiding geschreven
IUPUI, Team 2-2, Baechle Spring 2017 Lid van IUPUI, Team 2-2, Baechle Spring 2017
IUPUI-BAECHLE-S17S2G2
4 Leden
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 628
