Ga door naar hoofdinhoud
LG Optimus G Pro Earpiece Speaker Replacement
Wat je nodig hebt
  1. LG Optimus G Pro Earpiece Speaker Replacement, Remove Back Cover.: stap 1, afbeelding 1 van 1
    • Make sure before you begin working on your device, that the device is not charging.
    • Once you have access to the phone, there is a small indent on the bottom left side. Use your fingernail or a plastic opening tool to pry from here and pull off the back casing.
  2. LG Optimus G Pro Earpiece Speaker Replacement, Remove the Battery.: stap 2, afbeelding 1 van 1
    • Once you have properly removed the outer casing, the back should look as so.
    • To remove the battery, pull up from the red mark using your finger. The battery should come up at an angle, and easily be able to be removed.
    • Once the battery is removed you may safely proceed to the next step.
  3. LG Optimus G Pro Earpiece Speaker Replacement, Screw Removal: stap 3, afbeelding 1 van 2 LG Optimus G Pro Earpiece Speaker Replacement, Screw Removal: stap 3, afbeelding 2 van 2
    • Make sure you remove the battery first. You will see that there are 14 screws on the back of the inner case. Use the Phillips head screwdriver to remove each of the screws, make sure to put the screws in a safe place where they will not get lost.
  4. LG Optimus G Pro Earpiece Speaker Replacement, Remove Cover: stap 4, afbeelding 1 van 1
    • Once you have removed all the screws, you can begin removing the inside cover.
    • Insert the opening tool using a sliding motion into one of the corners and move it along the edges of the inside cover. This will loosen the edges and the inside cover will pry apart from the shell.
  5. LG Optimus G Pro Earpiece Speaker Replacement, Completion: stap 5, afbeelding 1 van 1
    • The inner cover is now removed, you now have access to the many parts on the inside of the phone.
  6. LG Optimus G Pro Earpiece Speaker Replacement, Remove the Ribbon Cable: stap 6, afbeelding 1 van 1
    • Using your plastic opening tool, disconnect the connection between the phone and the ribbon cable. Make sure to use even pressure as you apply it to the cable.
  7. LG Optimus G Pro Earpiece Speaker Replacement, Remove the Sisterboard.: stap 7, afbeelding 1 van 2 LG Optimus G Pro Earpiece Speaker Replacement, Remove the Sisterboard.: stap 7, afbeelding 2 van 2
    • In this next step it is easy to pry the wrong piece. Make sure to pry at the metal platform that the sister board sits on, not the orange printed circuit board itself.
    • Using your prying tool, pry at the right red marked corner, making sure to pull at the metal platform under the circuit board. Once it is raised slightly, pull along the underside until the left red mark. This should loosen the board and allow it to be removed.
    • If it's still unable to be removed, try to pry at the orange mark, making sure to pull at the same metal platform.
  8. LG Optimus G Pro Earpiece Speaker Replacement, Completed.: stap 8, afbeelding 1 van 1
    • You can now raise and remove the sisterboard with your plastic opening tool or your fingers.
  9. LG Optimus G Pro Earpiece Speaker Replacement, Remove Ribbon Cables: stap 9, afbeelding 1 van 2 LG Optimus G Pro Earpiece Speaker Replacement, Remove Ribbon Cables: stap 9, afbeelding 2 van 2
    • Use the plastic opening tool to disconnect the 4 ribbon cable connections and the antenna attached to the logic board.
  10. LG Optimus G Pro Earpiece Speaker Replacement, Remove Adhesive.: stap 10, afbeelding 1 van 1
    • The logic board is connected to the under side of the phone with a bit of adhesive. Using a spudger, place it under the logic board from the top right corner and gently slide it toward the center orange mark where the adhesive is. Apply a little bit of pressure parallel to the logic board and the Logic board should loosen from the phone.
  11. LG Optimus G Pro Earpiece Speaker Replacement, Remove the Speaker.: stap 11, afbeelding 1 van 1
    • Once you have completed the prerequisites, the speaker should be accessible for removal. Using one of the Plastic Opening Tools, you can remove the Front-Facing Speaker.
Conclusie
Wesley Pate
1.641 Reputatie
7 handleidingen geschreven
USF Tampa, Team 15-5, Remmell Fall 2014 Lid van USF Tampa, Team 15-5, Remmell Fall 2014
USFT-REMMELL-F14S15G5
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 1,995
