Ga door naar hoofdinhoud
LG Optimus G Pro Battery Replacement
Wat je nodig hebt
  1. LG Optimus G Pro Battery Replacement, Remove Back Cover.: stap 1, afbeelding 1 van 1
    • Make sure before you begin working on your device, that the device is not charging.
    • Once you have access to the phone, there is a small indent on the bottom left side. Use your fingernail or a plastic opening tool to pry from here and pull off the back casing.
  2. LG Optimus G Pro Battery Replacement, Remove the Battery.: stap 2, afbeelding 1 van 1
    • Once you have properly removed the outer casing, the back should look as so.
    • To remove the battery, pull up from the red mark using your finger. The battery should come up at an angle, and easily be able to be removed.
    • Once the battery is removed you may safely proceed to the next step.
Conclusie
10 andere personen hebben deze handleiding voltooid.
Wesley Pate
1.641 Reputatie
7 handleidingen geschreven
USF Tampa, Team 15-5, Remmell Fall 2014 Lid van USF Tampa, Team 15-5, Remmell Fall 2014
USFT-REMMELL-F14S15G5
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 3,202
