Ga door naar hoofdinhoud
LG Optimus G Battery Replacement
Wat je nodig hebt
  1. LG Optimus G Battery Replacement, Remove the simcard: stap 1, afbeelding 1 van 2 LG Optimus G Battery Replacement, Remove the simcard: stap 1, afbeelding 2 van 2
    • SIM eject tool
  2. LG Optimus G Battery Replacement, Remove the back cover: stap 2, afbeelding 1 van 2 LG Optimus G Battery Replacement, Remove the back cover: stap 2, afbeelding 2 van 2
    • Remove the 2 screws holding the back cover using a T5 screwdriver.
    • Use a guitar pick or a plastic opening tool to free the clips on the top and each side of the back cover.
    • Use an opening pick to pry off the rear case.
  3. LG Optimus G Battery Replacement, Removing the battery: stap 4, afbeelding 1 van 2 LG Optimus G Battery Replacement, Removing the battery: stap 4, afbeelding 2 van 2
    • Remove the tape over the battery, the screws and the antenna connector cord.
    • Be careful removing the golden tape because it is below the antenna connector cord.
  4. LG Optimus G Battery Replacement: stap 5, afbeelding 1 van 2 LG Optimus G Battery Replacement: stap 5, afbeelding 2 van 2
    • Remove the the screws securing the battery cable connector.
    • Disconnect the battery cable.
  5. LG Optimus G Battery Replacement: stap 6, afbeelding 1 van 1
    • The battery is held down by some adhesive.
    • Carefully heat the battery to loosen the adhesive holding it to the case.
  6. LG Optimus G Battery Replacement: stap 7, afbeelding 1 van 2 LG Optimus G Battery Replacement: stap 7, afbeelding 2 van 2
    • Pry the battery up from the case.
    • Be very careful not to puncture the battery when prying. Use blunt plastic tools.
  7. LG Optimus G Battery Replacement: stap 8, afbeelding 1 van 3 LG Optimus G Battery Replacement: stap 8, afbeelding 2 van 3 LG Optimus G Battery Replacement: stap 8, afbeelding 3 van 3
    • The battery is removed.
    • Replace the battery with a new one.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Eneider Colina
2.370 Reputatie
9 handleidingen geschreven
Comunidad para traductores de español Lid van Comunidad para traductores de español
Community
24 Leden
249 handleidingen geschreven
5 opmerkingen
“Heat gun”is too vague. So is IR thermometer. What temperature to soften adhesive? How would I know if I was buying the right things?
Deep - Antwoord
I’m not using a heat gun, it´s a hairdryer; on this case the hairdryer hardly exceeds the 60°C and that is enough to remove the battery. If you want to buy a heat gun you must be careful not to use more than 50 °
Eneider Colina - Antwoord
Where do you suggest ordering a replacement battery from?
snack le - Antwoord
you can search it on Amazon and buy directly from LG.
Eneider Colina -
Thank you so much for this wonderful article it helped me replace my battery. I bought my replacement battery from here:-
https://www.phonepartworld.com/LG/LG-Opt...
ricksanchez - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 16
Altijd: 5,135
