Ga door naar hoofdinhoud
LG Optimus F3 Headphone Jack Replacement
Wat je nodig hebt
  1. LG Optimus F3 Headphone Jack Replacement, Headphone Jack: stap 1, afbeelding 1 van 1
    • Place your thumb at the bottom of the phone's back where the charging port is located.
    • Gently pull the cover off.
  2. LG Optimus F3 Headphone Jack Replacement: stap 2, afbeelding 1 van 1
    • Using the indent at the bottom of the battery, lift and remove the battery from the phone.
    • Place the battery in a safe location as you will need it for reassembly.
  3. LG Optimus F3 Headphone Jack Replacement: stap 3, afbeelding 1 van 1
    • Remove the ten 1.0 mm screws on the rear case.
    • Place the screws in a safe location as you will need them for reassembly.
  4. LG Optimus F3 Headphone Jack Replacement: stap 4, afbeelding 1 van 1
    • Pry apart the joints to separate the inner case.
    • Insert the opening tool on different locations until the case comes off easily.
    • To avoid damaging the joints of the case do not pry if there is resistance.
  5. LG Optimus F3 Headphone Jack Replacement: stap 5, afbeelding 1 van 1
    • With the inner cover removed, locate your headphone jack.
    • It will be in the upper right corner on the back of the phone.
  6. LG Optimus F3 Headphone Jack Replacement: stap 6, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Gently grab the headphone jack along the sides with tweezers.
    • Lift the headphone jack out of its socket.
  7. LG Optimus F3 Headphone Jack Replacement: stap 7, afbeelding 1 van 1
    • Insert the new headphone jack into the headphone socket by lining up the connectors and gently pressing down.
    • Make sure the dark side without the connectors is face up.
Conclusie
To reassemble your device follow these steps in reverse order.
4 andere personen hebben deze handleiding voltooid.
Ryan McDermott
324 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 1-5, Miles Fall 2015 Lid van UMass Dartmouth, Team 1-5, Miles Fall 2015
UMASSD-MILES-F15S1G5
3 Leden
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 26
Altijd: 581
