Onderdelen
Geen onderdelen nodig.
  1. Slide the battery cover release towards top of phone.
    • Slide the battery cover release towards top of phone.
    • Place one finger at each side of the battery cover.
    • Lift and remove the battery cover.
  2. Place a finger at the top corner of the battery and lift out of the phone.
    • Place a finger at the top corner of the battery and lift out of the phone.
    • Use the spudger to lift up the two screw covers at the top of the phone.
    • Remove all four Phillips#00 (3.3mm) screws with screwdriver.
    • Use the spudger to lift up the rear case from the phone.
    • Note: Rear case is connected on all sides and will have to be detached on all sides before removal.
    • Remove the rear case from the device.
Conclusie
Matthew Cataldo
1 Reputatie
1 Handleiding geschreven
Cal Poly, Team 3-29, Amido Winter 2012 Lid van Cal Poly, Team 3-29, Amido Winter 2012
CPSU-AMIDO-W12S3G29
4 Leden
14 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 495
