Ga door naar hoofdinhoud
LG Muziq LX570 Keypad Replacement
Wat je nodig hebt
  1. LG Muziq LX570 Keypad Replacement, Battery: stap 1, afbeelding 1 van 2 LG Muziq LX570 Keypad Replacement, Battery: stap 1, afbeelding 2 van 2
    • Slide the battery cover release towards top of phone.
    • Place one finger at each side of the battery cover.
    • Lift and remove the battery cover.
  2. LG Muziq LX570 Keypad Replacement: stap 2, afbeelding 1 van 2 LG Muziq LX570 Keypad Replacement: stap 2, afbeelding 2 van 2
    • Place a finger at the top corner of the battery and lift out of the phone.
  3. LG Muziq LX570 Keypad Replacement, Rear Case: stap 3, afbeelding 1 van 2 LG Muziq LX570 Keypad Replacement, Rear Case: stap 3, afbeelding 2 van 2
    • Use the spudger to lift up the two screw covers at the top of the phone.
    • Remove all four Phillips#00 (3.3mm) screws with screwdriver.
  4. LG Muziq LX570 Keypad Replacement: stap 4, afbeelding 1 van 3 LG Muziq LX570 Keypad Replacement: stap 4, afbeelding 2 van 3 LG Muziq LX570 Keypad Replacement: stap 4, afbeelding 3 van 3
    • Use the spudger to lift up the rear case from the phone.
    • Note: Rear case is connected on all sides and will have to be detached on all sides before removal.
    • Remove the rear case from the device.
  5. LG Muziq LX570 Keypad Replacement, Motherboard: stap 5, afbeelding 1 van 3 LG Muziq LX570 Keypad Replacement, Motherboard: stap 5, afbeelding 2 van 3 LG Muziq LX570 Keypad Replacement, Motherboard: stap 5, afbeelding 3 van 3
    • Use the spudger to lift the motherboard from the phone.
  6. LG Muziq LX570 Keypad Replacement, Keypad: stap 6, afbeelding 1 van 3 LG Muziq LX570 Keypad Replacement, Keypad: stap 6, afbeelding 2 van 3 LG Muziq LX570 Keypad Replacement, Keypad: stap 6, afbeelding 3 van 3
    • Caution: The circuit board is connected via ribbon to the phone. Do not break this connection.
    • Note: The circuit board is attached by clips on both sides of the board. Detach each clip before removing the motherboard from the phone.
    • Use the spudger to detach the circuit board from the phone.
  7. LG Muziq LX570 Keypad Replacement: stap 7, afbeelding 1 van 3 LG Muziq LX570 Keypad Replacement: stap 7, afbeelding 2 van 3 LG Muziq LX570 Keypad Replacement: stap 7, afbeelding 3 van 3
    • Open the phone to expose the keypad.
    • Use your finger to push the keypad from the front towards the circuit board.
    • Remove the keypad from the phone.
Conclusie
Braden Burk
1 Reputatie
5 handleidingen geschreven
Cal Poly, Team 3-29, Amido Winter 2012 Lid van Cal Poly, Team 3-29, Amido Winter 2012
CPSU-AMIDO-W12S3G29
4 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 4
Altijd: 723
