Ga door naar hoofdinhoud
LG Muziq LX570 Front Case Replacement
Wat je nodig hebt
  1. LG Muziq LX570 Front Case Replacement, Front Case: stap 1, afbeelding 1 van 2 LG Muziq LX570 Front Case Replacement, Front Case: stap 1, afbeelding 2 van 2
    • Use a spudger to remove the two screw covers below display.
    • Use a screw driver to remove the four Phillips #00 (3.3mm) screws at corners of the display.
  2. LG Muziq LX570 Front Case Replacement: stap 2, afbeelding 1 van 3 LG Muziq LX570 Front Case Replacement: stap 2, afbeelding 2 van 3 LG Muziq LX570 Front Case Replacement: stap 2, afbeelding 3 van 3
    • Caution: Wires and ribbon connect the front case to the main body. Exhibit care when separating front case from the main body as to not break the connections.
    • Note: Side buttons may fall out when removing the front case. Do not misplace them.
    • Note: Each side button will only fit in the side that it came from.
    • Insert a spudger between the black and grey casings and gently spread them apart.
    • Work around the device gradually, opening the gap further.
  3. LG Muziq LX570 Front Case Replacement: stap 3, afbeelding 1 van 3 LG Muziq LX570 Front Case Replacement: stap 3, afbeelding 2 van 3 LG Muziq LX570 Front Case Replacement: stap 3, afbeelding 3 van 3
    • Caution: The wires and ribbon connector can break easily. Exhibit care when removing them.
    • Use the spudger and lift upward to disconnect the ribbon from the main part of the phone.
    • Carefully remove any parts stuck to the front case such as speakers.
Conclusie
Raymond Ching
1 Reputatie
1 Handleiding geschreven
Cal Poly, Team 3-29, Amido Winter 2012 Lid van Cal Poly, Team 3-29, Amido Winter 2012
CPSU-AMIDO-W12S3G29
4 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 571
