Ga door naar hoofdinhoud
LG Muziq LX570 Display Panel Replacement
Wat je nodig hebt
    1. LG Muziq LX570 Display Panel Replacement, Front Case: stap 1, afbeelding 1 van 2 LG Muziq LX570 Display Panel Replacement, Front Case: stap 1, afbeelding 2 van 2
      • Use a spudger to remove the two screw covers below display.
      • Use a screw driver to remove the four Phillips #00 (3.3mm) screws at corners of the display.
      Vraag FixBot
      Voeg opmerking toe
    2. LG Muziq LX570 Display Panel Replacement: stap 2, afbeelding 1 van 3 LG Muziq LX570 Display Panel Replacement: stap 2, afbeelding 2 van 3 LG Muziq LX570 Display Panel Replacement: stap 2, afbeelding 3 van 3
      • Caution: Wires and ribbon connect the front case to the main body. Exhibit care when separating front case from the main body as to not break the connections.
      • Note: Side buttons may fall out when removing the front case. Do not misplace them.
      • Note: Each side button will only fit in the side that it came from.
      • Insert a spudger between the black and grey casings and gently spread them apart.
      • Work around the device gradually, opening the gap further.
      Vraag FixBot
      Voeg opmerking toe
    3. LG Muziq LX570 Display Panel Replacement: stap 3, afbeelding 1 van 3 LG Muziq LX570 Display Panel Replacement: stap 3, afbeelding 2 van 3 LG Muziq LX570 Display Panel Replacement: stap 3, afbeelding 3 van 3
      • Caution: The wires and ribbon connector can break easily. Exhibit care when removing them.
      • Use the spudger and lift upward to disconnect the ribbon from the main part of the phone.
      • Carefully remove any parts stuck to the front case such as speakers.
      Vraag FixBot
      Voeg opmerking toe
    1. LG Muziq LX570 Display Panel Replacement, Display Panel: stap 4, afbeelding 1 van 3 LG Muziq LX570 Display Panel Replacement, Display Panel: stap 4, afbeelding 2 van 3 LG Muziq LX570 Display Panel Replacement, Display Panel: stap 4, afbeelding 3 van 3
      • Use the spudger to unclip the two upper wiring connections.
      Vraag FixBot
      Voeg opmerking toe
    2. LG Muziq LX570 Display Panel Replacement: stap 5, afbeelding 1 van 2 LG Muziq LX570 Display Panel Replacement: stap 5, afbeelding 2 van 2
      • Caution: The side buttons are attached to the ribbon around the display screen. Do not separate the side buttons from the ribbon when removing.
      • Gently lift the side buttons from the phone casing.
      Vraag FixBot
      Voeg opmerking toe
    3. LG Muziq LX570 Display Panel Replacement: stap 6, afbeelding 1 van 3 LG Muziq LX570 Display Panel Replacement: stap 6, afbeelding 2 van 3 LG Muziq LX570 Display Panel Replacement: stap 6, afbeelding 3 van 3
      • Caution: The wiring on the ribbon connector is delicate. Do not excessively pull on the wires.
      • Use the spudger to remove the three components connected to the ribbon.
      Vraag FixBot
      Voeg opmerking toe
    4. LG Muziq LX570 Display Panel Replacement: stap 7, afbeelding 1 van 3 LG Muziq LX570 Display Panel Replacement: stap 7, afbeelding 2 van 3 LG Muziq LX570 Display Panel Replacement: stap 7, afbeelding 3 van 3
      • Caution: The ribbon contains important wiring and is glued to the phone. Be careful when removing the ribbon.
      • Use the spudger to gently remove the ribbon from the phone.
      Vraag FixBot
      Voeg opmerking toe
    5. LG Muziq LX570 Display Panel Replacement: stap 8, afbeelding 1 van 3 LG Muziq LX570 Display Panel Replacement: stap 8, afbeelding 2 van 3 LG Muziq LX570 Display Panel Replacement: stap 8, afbeelding 3 van 3
      • Use the spudger to lift the upper tab in the top left corner of the display.
      • Continue lifting until the display panels lift out of their setting and can be removed.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Braden Burk
1 Reputatie
5 handleidingen geschreven
Cal Poly, Team 3-29, Amido Winter 2012 Lid van Cal Poly, Team 3-29, Amido Winter 2012
CPSU-AMIDO-W12S3G29
4 Leden
49 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 32
Altijd: 1,355
