Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
If the speaker is blown or no sound is coming out this will show you how to replace a broken speaker.
Onderdelen
Geen onderdelen opgegeven.
  1. Use a plastic opening tool to remove the back cover.
    • Use a plastic opening tool to remove the back cover.
  2. Use a plastic opening tool to remove the battery, lifting from the bottom right corner.
    • Use a plastic opening tool to remove the battery, lifting from the bottom right corner.
  3. Use a Phillips #00 Screwdriver to remove all eight 4mm screws.
    • Use a Phillips #00 Screwdriver to remove all eight 4mm screws.
  4. Use a plastic opening tool to remove the back trim by working around all of the edges. Use a plastic opening tool to remove the back trim by working around all of the edges.
    • Use a plastic opening tool to remove the back trim by working around all of the edges.
  5. Remove the volume buttons from the side. Remove the volume buttons from the side.
    • Remove the volume buttons from the side.
  6. Use a plastic opening tool to lift the speaker off by prying under the silver square as shown. Note: There is a small tab underneath the speaker that will be lifted off when the speaker is removed.
    • Use a plastic opening tool to lift the speaker off by prying under the silver square as shown.
    • Note: There is a small tab underneath the speaker that will be lifted off when the speaker is removed.
Conclusie
Daniela Allbright
605 Reputatie
3 handleidingen geschreven
USF Tampa, Team 14-1, Leahy Fall 2014 Lid van USF Tampa, Team 14-1, Leahy Fall 2014
USFT-LEAHY-F14S14G1
3 Leden
5 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 182
