Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Use a plastic opening tool to remove the back cover.
Use a plastic opening tool to remove the battery, lifting from the bottom right corner.
Use a Phillips #00 Screwdriver to remove all eight 4mm screws.
Use a plastic opening tool to remove the back trim by working around all of the edges.
Use a plastic opening tool to lift the speaker off by prying under the silver square as shown.
Pry slightly underneath the tab attached to the camera until it pops off.
Gereedschap gebruikt in deze stap:Tweezers$4.99-
Use tweezers to remove the camera, you will need to use some force as it is glued on.
Één andere persoon heeft deze handleiding voltooid.
