Ga door naar hoofdinhoud
LG Motion 4G MS770 Motherboard Replacement
Wat je nodig hebt
  1. LG Motion 4G MS770 Motherboard Replacement, Remove the phone's back cover.: stap 1, afbeelding 1 van 1
    • Use a plastic opening tool to remove the back cover.
  2. LG Motion 4G MS770 Motherboard Replacement, Remove the battery.: stap 2, afbeelding 1 van 1
    • Use a plastic opening tool to remove the battery, lifting from the bottom right corner.
  3. LG Motion 4G MS770 Motherboard Replacement, Remove screws.: stap 3, afbeelding 1 van 1
    • Use a Phillips #00 Screwdriver to remove all eight 4mm screws.
  4. LG Motion 4G MS770 Motherboard Replacement: stap 4, afbeelding 1 van 2 LG Motion 4G MS770 Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Use a plastic opening tool to remove the back trim by working around all of the edges.
  5. LG Motion 4G MS770 Motherboard Replacement: stap 5, afbeelding 1 van 2 LG Motion 4G MS770 Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Remove the volume buttons from the side.
  6. LG Motion 4G MS770 Motherboard Replacement, Speaker: stap 6, afbeelding 1 van 2 LG Motion 4G MS770 Motherboard Replacement, Speaker: stap 6, afbeelding 2 van 2
    • Use a plastic opening tool to lift the speaker off by prying under the silver square as shown.
    • Note: There is a small tab underneath the speaker that will be lifted off when the speaker is removed.
  7. LG Motion 4G MS770 Motherboard Replacement, Rear Facing Camera: stap 7, afbeelding 1 van 1
    • Pry slightly underneath the tab attached to the camera until it pops off.
  8. LG Motion 4G MS770 Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Use tweezers to remove the camera, you will need to use some force as it is glued on.
  9. LG Motion 4G MS770 Motherboard Replacement, Motherboard: stap 9, afbeelding 1 van 1
    • Pry off the circled tabs using a plastic opening tool to release the motherboard.
  10. LG Motion 4G MS770 Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Lift the motherboard off of the phone. It should come right out.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Zarna Patel
320 Reputatie
2 handleidingen geschreven
USF Tampa, Team 14-1, Leahy Fall 2014 Lid van USF Tampa, Team 14-1, Leahy Fall 2014
USFT-LEAHY-F14S14G1
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 1,291
