Inleiding
If nothing seems to work when trying to fix your phone, then more than likely a new motherboard is all you need to fix your phone. This guide will show you how to replace your motherboard.
Wat je nodig hebt
Place the phone on a flat surface with the back facing upward.
Remove the back panel by placing your thumb on the LG logo and sliding the panel in a downward motion until the panel is removed.
Before continuing pull off all the rubber tabs to the headphones, and the power input.
Gereedschap gebruikt in deze stap:Tweezers$4.99
At the top of the logic board there is a small rectangle with a white pad on it, use your tweezers and gently grip the neck of the orange wire.
Gently pull up on the orange wire until it comes loose. It may take some force so do not be concerned with being overly gentle.
