Inleiding
This guide will show you how to replace a worn out, scratched, or damaged internal keyboard on the LG LX160 cell phone. To begin this guide, complete steps 1 to 10 of the tear down guide
Wat je nodig hebt
Place the phone on a flat surface with the back facing upward.
Remove the back panel by placing your thumb on the LG logo and sliding the panel in a downward motion until the panel is removed.
Before continuing pull off all the rubber tabs to the headphones, and the power input.
Gereedschap gebruikt in deze stap:Tweezers$4.99
At the top of the logic board there is a small rectangle with a white pad on it, use your tweezers and gently grip the neck of the orange wire.
Gently pull up on the orange wire until it comes loose. It may take some force so do not be concerned with being overly gentle.
Peel out the keypad in the back of the phone. It is the white flimsy plastic from the bottom.
