Inleiding
This guide will show you how to remove the plastic cover between the battery and motherboard.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
First locate the button and the bottom of the cover where the arrow is. Press down on the button.
While pushing down on the button, slide the cover up towards the hinge until the cover comes off.
The battery will be visible after removing the back cover.
Remove the 7 phillips screws indicated by the red arrows using the phillips #0 screwdriver.
Insert the flat end of the spudger in-between the black and blue phone casing on the side of the phone and split the the blue and black apart. Work your way around the perimeter of the cover, loosening all corners.
Één andere persoon heeft deze handleiding voltooid.
