Ga door naar hoofdinhoud
LG L1200 Camera Replacement
Wat je nodig hebt
  1. LG L1200 Camera Replacement, Inner LCD Screen: stap 1, afbeelding 1 van 1
    • Make sure you remove the battery by lifting the tab on the back of the phone before opening the case.
    • Flip open the phone and locate the four screw covers.
  2. LG L1200 Camera Replacement: stap 2, afbeelding 1 van 1
    • Remove all four screw covers by using an IPod opening tool. They should come off relatively easy.
  3. LG L1200 Camera Replacement: stap 3, afbeelding 1 van 1
    • Using a T6 Torx screwdriver, remove all four screws.
  4. LG L1200 Camera Replacement: stap 4, afbeelding 1 van 3 LG L1200 Camera Replacement: stap 4, afbeelding 2 van 3 LG L1200 Camera Replacement: stap 4, afbeelding 3 van 3
    • Once the screws are removed, use an IPod opening tool to separate the front cover from the inner screen cover.
    • Run the Ipod opening tool down both sides,disconnecting the tabs that hold the covers together.
  5. LG L1200 Camera Replacement: stap 5, afbeelding 1 van 2 LG L1200 Camera Replacement: stap 5, afbeelding 2 van 2
    • Pull the inner screen cover towards you and up in order to separate it from the front cover.
  6. LG L1200 Camera Replacement: stap 6, afbeelding 1 van 1
    • Remove the tape from the bottom of the LCD screen.
  7. LG L1200 Camera Replacement: stap 7, afbeelding 1 van 3 LG L1200 Camera Replacement: stap 7, afbeelding 2 van 3 LG L1200 Camera Replacement: stap 7, afbeelding 3 van 3
    • Carefully lift the LCD screen and peel it from the gold ribbon. The sticky connection runs all the way around the LCD screen.
  8. LG L1200 Camera Replacement: stap 8, afbeelding 1 van 3 LG L1200 Camera Replacement: stap 8, afbeelding 2 van 3 LG L1200 Camera Replacement: stap 8, afbeelding 3 van 3
    • Flip the screen over so that you can see the outer LCD screen and the circuit board.
    • Insert spudger in the bottom right corner.
    • Lift up and move the spudger across the bottom.
    • The third photo is rotated 180 degrees.
  9. LG L1200 Camera Replacement: stap 9, afbeelding 1 van 2 LG L1200 Camera Replacement: stap 9, afbeelding 2 van 2
    • Use the pointy side of the spudger to peel off the interior tape.
    • Flip the assembly over and peel the circuit board from the screen.
  10. LG L1200 Camera Replacement: stap 10, afbeelding 1 van 2 LG L1200 Camera Replacement: stap 10, afbeelding 2 van 2
    • Use the spudger to remove the LCD screen from its backing.
  11. LG L1200 Camera Replacement, Camera: stap 11, afbeelding 1 van 1
    • Carefully slide the spudger behind the main ribbon in order to separate it from the inside cover of the phone.
  12. LG L1200 Camera Replacement: stap 12, afbeelding 1 van 2 LG L1200 Camera Replacement: stap 12, afbeelding 2 van 2
    • Use a spudger to pop off the camera ribbon from the main ribbon. The camera component should separate entirely.
Conclusie
Joshua Herrmann
8 Reputatie
8 handleidingen geschreven
Cal Poly, Team 6-14, Maness Spring 2010 Lid van Cal Poly, Team 6-14, Maness Spring 2010
CPSU-MANESS-S10S6G14
4 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 1,221
