Ga door naar hoofdinhoud
LG KP100 SIM Card Replacement
  1. LG KP100 SIM Card Replacement, Battery: stap 1, afbeelding 1 van 2 LG KP100 SIM Card Replacement, Battery: stap 1, afbeelding 2 van 2
    • Begin by taking the back battery cover off.
    • Put your index finger on the white notch and apply pressure.
    • While applying pressure, move your hand backwards to slide the battery cover off of the body of the phone.
  2. LG KP100 SIM Card Replacement: stap 2, afbeelding 1 van 2 LG KP100 SIM Card Replacement: stap 2, afbeelding 2 van 2
    • Remove the battery.
    • Put your index finger in the notch above the battery near the top of the casing.
    • While applying pressure against the battery, lift up and take out the battery.
  3. LG KP100 SIM Card Replacement, SIM Card: stap 3, afbeelding 1 van 3 LG KP100 SIM Card Replacement, SIM Card: stap 3, afbeelding 2 van 3 LG KP100 SIM Card Replacement, SIM Card: stap 3, afbeelding 3 van 3
    • Remove the SIM card from its housing.
    • Put your finger in the provided notch below the SIM card and begin to push the SIM card towards the top of the device.
    • After it is out of the metal housing, it is free to be removed.
Conclusie
Preston Brown
28 Reputatie
5 handleidingen geschreven
Cal Poly, Team 6-20, Amido Spring 2012 Lid van Cal Poly, Team 6-20, Amido Spring 2012
CPSU-AMIDO-S12S6G20
4 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 18
Altijd: 1,512
