Inleiding
Your carrier will provide you with a removable 3.7V Lithium Ion battery, which is the power source of the phone. While using the phone, you might need to remove the battery to access other components of the phone.
Begin by taking the back battery cover off.
Put your index finger on the white notch and apply pressure.
While applying pressure, move your hand backwards to slide the battery cover off of the body of the phone.
