Ga door naar hoofdinhoud
LG K92 5G Screen Replacement
Video overzicht
  1. LG K92 5G Screen Replacement, Removing the Back Panel: stap 1, afbeelding 1 van 1
    • Heat the plastic back panel with a heatgun or heating pad.
    • Use a thin metal pry tool or razor to separate the adhesive from the frame, and peel the back cover off.
  2. LG K92 5G Screen Replacement, Remove antenna board and screws: stap 2, afbeelding 1 van 2 LG K92 5G Screen Replacement, Remove antenna board and screws: stap 2, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Remove 11 same-sized phillips screws from the top antenna panel.
    • Using tweezers, forcefully pop the panel from a safe area up and out of the housing, the lower middle screw hole is a good area to apply leverage.
  3. LG K92 5G Screen Replacement, Remove lower speaker and screws: stap 3, afbeelding 1 van 2 LG K92 5G Screen Replacement, Remove lower speaker and screws: stap 3, afbeelding 2 van 2
    • Remove 8 more identically sized phillips screws from the lower antenna and speaker panel.
    • Pop the lower panel off with tweezers, it should come off relatively easier than the previous panel.
  4. LG K92 5G Screen Replacement, Disconnect almost everything: stap 4, afbeelding 1 van 1
    • Disconnect the battery first!
    • Then disconnect the other main lego style connectors and ribbons. There is no need to disconnect the cameras.
  5. LG K92 5G Screen Replacement, Pull the main logic board out: stap 5, afbeelding 1 van 1
    • Remove the main logic board by pulling from the top and lifting it out.
  6. LG K92 5G Screen Replacement, Remove charging port board: stap 6, afbeelding 1 van 1
    • Remove the single Phillips screw from the charging daughterboard, and pull it out of the frame.
    • (Optional) Leave the antenna lines connected to reduce risk of breaking them.
  7. LG K92 5G Screen Replacement, Extract the power button/fingerprint reader: stap 7, afbeelding 1 van 2 LG K92 5G Screen Replacement, Extract the power button/fingerprint reader: stap 7, afbeelding 2 van 2
    • The power button has a small pressure connected ribbon that is adhered to the frame, carefully pry it up.
    • The fingerprint reader itself is on a separate lego style connector that can then be fished out.
  8. LG K92 5G Screen Replacement, Remove volume and quick button flex: stap 8, afbeelding 1 van 1
    • Gently pull the pressure connection pad up from the frame, then work the ribbon out from the trench.
  9. LG K92 5G Screen Replacement, Extract Volume and Quick Action keys: stap 9, afbeelding 1 van 1
    • Using tweezers or a bent pry tool, push the buttons out from inside of the frame.
  10. LG K92 5G Screen Replacement, Remove small components: stap 10, afbeelding 1 van 1
    • Some small components like the vibration motor, antenna sticker, or earspeaker may need to be moved to the new frame.
  11. LG K92 5G Screen Replacement, Battery removal: stap 11, afbeelding 1 van 1
    • Use a heating pad to warm the device from the front, apply generous amounts of alcohol to the battery compartment and carefully lift it out.
    • Avoid bending the battery as this can compromise the internal cells.
  12. LG K92 5G Screen Replacement, Install components in the replacement frame: stap 12, afbeelding 1 van 2 LG K92 5G Screen Replacement, Install components in the replacement frame: stap 12, afbeelding 2 van 2
    • Remove protective plastics from the replacement frame.
    • Reinstall components in the order in which they were removed. Be sure to align the antenna wires carefully to prevent pinching issues.
  13. LG K92 5G Screen Replacement, Finish it up!: stap 13, afbeelding 1 van 1
    • Reinstall remaining components and tighten screws in their respective locations.
    • Always test the device prior to sealing the back panel on with new adhesive.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Taptic Digital
250 Reputatie
1 Handleiding geschreven
4Gids Commentaar
Why is there no reassembly guide?
Zach Benson - Antwoord Deel
Follow the steps in reverse order.
Taptic Digital - Deel
What is the black item adhered on top of the battery, with the connector!
JS1 - Antwoord Deel
NFC coil, it is not a wireless charging coil despite being similar in appearance.
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 21
Altijd: 2,577
