Ga door naar hoofdinhoud
LG K7 Volume & On/Off Buttons Replacement
Wat je nodig hebt
  1. LG K7 Volume & On/Off Buttons Replacement, Volume & On/Off Buttons: stap 1, afbeelding 1 van 2 LG K7 Volume & On/Off Buttons Replacement, Volume & On/Off Buttons: stap 1, afbeelding 2 van 2
    • Remove the back cover using a plastic opening tool.
    • Remove the battery using a plastic opening tool.
  2. LG K7 Volume & On/Off Buttons Replacement: stap 2, afbeelding 1 van 1
    • Remove the nine 4mm Phillips #000 screws.
    • The cover should lift off easily once the screws are out.
    • Be gentle with the frame when removing it. The plastic is very thin and can easily break.
  3. LG K7 Volume & On/Off Buttons Replacement: stap 3, afbeelding 1 van 1
    • Pry off the silver button housing using the plastic opening tool.
  4. LG K7 Volume & On/Off Buttons Replacement: stap 4, afbeelding 1 van 1
    • Separate the screen from the rest of the phone using the plastic opening tool.
    • The frame is held to the rest of the phone with plastic tabs. Release each tab one at a time around the phone for the easiest removal.
    • Do not bend the outer frame or screen when separating them. This will severely damage the phone.
  5. LG K7 Volume & On/Off Buttons Replacement: stap 5, afbeelding 1 van 3 LG K7 Volume & On/Off Buttons Replacement: stap 5, afbeelding 2 van 3 LG K7 Volume & On/Off Buttons Replacement: stap 5, afbeelding 3 van 3
    • Peel off the orange cable using a plastic opening tool.
  6. LG K7 Volume & On/Off Buttons Replacement: stap 6, afbeelding 1 van 1
    • Remove the volume/power button cable from the rest of the phone using the plastic opening tool to break the adhesive.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jack Lepkowski
136 Reputatie
1 Handleiding geschreven
IUPUI, Team S3-G2, Harley Fall 2019 Lid van IUPUI, Team S3-G2, Harley Fall 2019
IUPUI-HARLEY-F19S3G2
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 9
Altijd: 499
