Ga door naar hoofdinhoud
LG K7 T-Mobile Rear Phone Camera Replacement
Wat je nodig hebt
  1. LG K7 T-Mobile Rear Phone  Camera Replacement, Battery: stap 1, afbeelding 1 van 2 LG K7 T-Mobile Rear Phone  Camera Replacement, Battery: stap 1, afbeelding 2 van 2
    • Flip the LG K7 over so that the back of the phone is facing up.
    • Locate the small notch on the bottom left side of the phone.
  2. LG K7 T-Mobile Rear Phone  Camera Replacement: stap 2, afbeelding 1 van 1
    • Insert a plastic opening tool into the notch and lift the back cover upward while holding the bottom portion of the phone down to remove it.
  3. LG K7 T-Mobile Rear Phone  Camera Replacement: stap 3, afbeelding 1 van 1
    • Remove the battery.
  4. LG K7 T-Mobile Rear Phone  Camera Replacement, Rear Phone  Camera: stap 4, afbeelding 1 van 2 LG K7 T-Mobile Rear Phone  Camera Replacement, Rear Phone  Camera: stap 4, afbeelding 2 van 2
    • Located to nine 3.4 mm screws that keep that keep the phones rear housing in tacked.
    • Using a Phillips 00 screwdriver remove all nine 3.4 mm screws.
  5. LG K7 T-Mobile Rear Phone  Camera Replacement: stap 5, afbeelding 1 van 3 LG K7 T-Mobile Rear Phone  Camera Replacement: stap 5, afbeelding 2 van 3 LG K7 T-Mobile Rear Phone  Camera Replacement: stap 5, afbeelding 3 van 3
    • Turn the phone over so the screen is facing up
    • Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
    • Slide the plastic opening tool down the seams carefully to separate the screen from the rest of the phone housing.
  6. LG K7 T-Mobile Rear Phone  Camera Replacement: stap 6, afbeelding 1 van 3 LG K7 T-Mobile Rear Phone  Camera Replacement: stap 6, afbeelding 2 van 3 LG K7 T-Mobile Rear Phone  Camera Replacement: stap 6, afbeelding 3 van 3
    • Locate the ribbon cable that holds the camera's ribbon cable in place.
    • Carefully remove the camera's ribbon cable from the motherboard using the plastic removal tool.
    • Holding the camera ribbon you just released pull upwards and the camera should release from the case.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Salem Jean
216 Reputatie
1 Handleiding geschreven
USF Tampa, Team S2-G5, Nance Fall 2017 Lid van USF Tampa, Team S2-G5, Nance Fall 2017
USFT-NANCE-F17S2G5
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 6
Altijd: 580
