Ga door naar hoofdinhoud
LG K7 T-Mobile Motherboard Replacement
Wat je nodig hebt
  1. LG K7 T-Mobile Motherboard Replacement, Battery: stap 1, afbeelding 1 van 2 LG K7 T-Mobile Motherboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • Flip the LG K7 over so that the back of the phone is facing up.
    • Locate the small notch on the bottom left side of the phone.
  2. LG K7 T-Mobile Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Insert a plastic opening tool into the notch and lift the back cover upward while holding the bottom portion of the phone down to remove it.
  3. LG K7 T-Mobile Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Remove the battery.
  4. LG K7 T-Mobile Motherboard Replacement, Motherboard: stap 4, afbeelding 1 van 2 LG K7 T-Mobile Motherboard Replacement, Motherboard: stap 4, afbeelding 2 van 2
    • Located to nine 3.4 mm screws that keep that keep the phones rear housing in tacked.
    • Using a Phillips 00 screwdriver remove all nine 3.4 mm screws.
  5. LG K7 T-Mobile Motherboard Replacement: stap 5, afbeelding 1 van 3 LG K7 T-Mobile Motherboard Replacement: stap 5, afbeelding 2 van 3 LG K7 T-Mobile Motherboard Replacement: stap 5, afbeelding 3 van 3
    • Turn the phone over so the screen is facing up.
    • Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
    • Slide the plastic opening tool down the seams carefully to separate the screen from the rest of the phone housing.
  6. LG K7 T-Mobile Motherboard Replacement: stap 6, afbeelding 1 van 3 LG K7 T-Mobile Motherboard Replacement: stap 6, afbeelding 2 van 3 LG K7 T-Mobile Motherboard Replacement: stap 6, afbeelding 3 van 3
    • Locate the lock that holds the camera's ribbon cable in place.
    • Carefully remove the camera's ribbon cable from the motherboard using the plastic removal tool.
    • Holding the camera ribbon you just released pull upwards and the camera should release from the case.
  7. LG K7 T-Mobile Motherboard Replacement: stap 7, afbeelding 1 van 2 LG K7 T-Mobile Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Locate the headphone jack towards the bottom right of the phone.
    • Place a plastic removal tool underneath the head phone jack.
    • Lift the plastic removal tool upward to remove the earphone jack from the phone case.
  8. LG K7 T-Mobile Motherboard Replacement: stap 8, afbeelding 1 van 2 LG K7 T-Mobile Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Locate the ribbon for the front facing camera.
    • Carefully remove the front facing camera's ribbon cable from the motherboard using the plastic removal tool.
    • Holding the front camera ribbon you just released pull upwards and the camera should release from the case.
    • Remove the band that connects the screen display to the motherboard.
  9. LG K7 T-Mobile Motherboard Replacement: stap 9, afbeelding 1 van 2 LG K7 T-Mobile Motherboard Replacement: stap 9, afbeelding 2 van 2
    • Locate the ribbon cable that connects the screen to the motherboard.
    • Carefully remove the screen's ribbon cable from the motherboard using the plastic removal tool by lifting the ribbon cable upwards.
  10. LG K7 T-Mobile Motherboard Replacement: stap 10, afbeelding 1 van 3 LG K7 T-Mobile Motherboard Replacement: stap 10, afbeelding 2 van 3 LG K7 T-Mobile Motherboard Replacement: stap 10, afbeelding 3 van 3
    • Wedge a plastic opening tool between the motherboard and the phones casing.
    • While using one finger to hold down a portion of the phone pull upwards with the plastic opening tool to loosen the motherboard from the phone casing.
    • Once there is some space between the board and the phone case, using your hands carefully lift the motherboard from the phone casing.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Brandon Jones
233 Reputatie
1 Handleiding geschreven
USF Tampa, Team S2-G5, Nance Fall 2017 Lid van USF Tampa, Team S2-G5, Nance Fall 2017
USFT-NANCE-F17S2G5
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 2,166
