Ga door naar hoofdinhoud
LG K7 Headphone Jack Replacement
Wat je nodig hebt
  1. LG K7 Headphone Jack Replacement, Battery: stap 1, afbeelding 1 van 2 LG K7 Headphone Jack Replacement, Battery: stap 1, afbeelding 2 van 2
    • Place a fingernail in slot at in the bottom edge of the phone.
    • Pull up on the back panel while holding down the rest of the phone steady with your hand.
    • Do not to pull too hard on the back panel or you may break it.
  2. LG K7 Headphone Jack Replacement: stap 2, afbeelding 1 van 2 LG K7 Headphone Jack Replacement: stap 2, afbeelding 2 van 2
    • Place a fingernail in the slot at the bottom edge of the battery.
    • Pull the battery out.
  3. LG K7 Headphone Jack Replacement, Headphone Jack: stap 3, afbeelding 1 van 3 LG K7 Headphone Jack Replacement, Headphone Jack: stap 3, afbeelding 2 van 3 LG K7 Headphone Jack Replacement, Headphone Jack: stap 3, afbeelding 3 van 3
    • Remove the nine frame screws with a #J00 screwdriver.
    • The bottom three screws release the port cover at the bottom of the phone. The cover should lift off easily once the screws are out.
    • Pop the camera button frame off with a spudger. The home button should come off along with the frame.
    • Be gentle with the frame when removing it. The plastic is very thin and can easily break.
  4. LG K7 Headphone Jack Replacement: stap 4, afbeelding 1 van 2 LG K7 Headphone Jack Replacement: stap 4, afbeelding 2 van 2
    • Use a plastic opening tool to separate the screen from the outer frame.
    • The frame is held to the rest of the phone with plastic tabs. Release each tab one at a time around the phone for the easiest removal.
    • Do not bend the outer frame or screen when separating them. This will severely damage the phone.
  5. LG K7 Headphone Jack Replacement: stap 5, afbeelding 1 van 1
    • Line up a plastic opening tool underneath the headphone jack and hold the main body of the phone down.
    • Lift or the plastic opening tool to separate the headphone jack from the main body of the phone.
    • Be careful to not damage the components that the headphone jack sits in.
Conclusie
James Ngo
461 Reputatie
4 handleidingen geschreven
Cal Poly, Team S21-G5, Banghart Winter 2018 Lid van Cal Poly, Team S21-G5, Banghart Winter 2018
CPSU-BANGHART-W18S21G5
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 961
