Ga door naar hoofdinhoud
LG K7 Charging Port Replacement
Wat je nodig hebt
  1. LG K7 Charging Port Replacement, Charging Port: stap 1, afbeelding 1 van 2 LG K7 Charging Port Replacement, Charging Port: stap 1, afbeelding 2 van 2
    • Remove the back cover by using the plastic opening tool.
    • Remove battery by using the plastic opening tool.
  2. LG K7 Charging Port Replacement: stap 2, afbeelding 1 van 1
    • Remove the nine 4mm Phillips #000 screws.
    • The cover should lift off easily once the screws are out.
    • Be gentle with the frame when removing it. The plastic is very thin and can easily break.
  3. LG K7 Charging Port Replacement: stap 3, afbeelding 1 van 1
    • Place the plastic opening tool between the screen and the plastic edge of the phone and pry carefully until screen pops off.
    • The frame is held to the rest of the phone with plastic tabs. Release each tab one at a time around the phone for the easiest removal.
    • Do not bend the outer frame or screen when separating them. This will severely damage the phone.
  4. LG K7 Charging Port Replacement: stap 4, afbeelding 1 van 1
    • Place the plastic opening tool between the blue motherboard and black plate and pry until the motherboard pops off.
  5. LG K7 Charging Port Replacement: stap 5, afbeelding 1 van 2 LG K7 Charging Port Replacement: stap 5, afbeelding 2 van 2
    • Heat up the four connection points using a soldering iron.
    • Once hot, gently push the port off.
    • Soldering iron is hot! Use with caution.
    • Be careful not to touch other components with the soldering iron.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Stephen Damm
167 Reputatie
1 Handleiding geschreven
IUPUI, Team S3-G2, Harley Fall 2019 Lid van IUPUI, Team S3-G2, Harley Fall 2019
IUPUI-HARLEY-F19S3G2
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 559
