Ga door naar hoofdinhoud
LG K30 Screen Replacement
Wat je nodig hebt
  1. LG K30 Screen Replacement, Battery: stap 1, afbeelding 1 van 2 LG K30 Screen Replacement, Battery: stap 1, afbeelding 2 van 2
    • Before disassembling your LG K30, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your Phone before beginning disassembly.
    • Use the 'Jimmy' and 'Metal Spudger' to slowly pry open the outsides of the back case.
  2. LG K30 Screen Replacement: stap 2, afbeelding 1 van 1
    • Remove the thirteen 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
  3. LG K30 Screen Replacement: stap 3, afbeelding 1 van 1
    • Use a metal spudger or plastic opening tool to pry open the outer cover.
  4. LG K30 Screen Replacement: stap 4, afbeelding 1 van 1
    • Use the flat end of a spudger to detach the battery connector from the logic board.
  5. LG K30 Screen Replacement: stap 5, afbeelding 1 van 2 LG K30 Screen Replacement: stap 5, afbeelding 2 van 2
    • Use a spudger to pry the battery from the phone.
    • There may be an adhesive on the back of the battery and the phone. Pry the battery gently to prevent puncture or damage.
    • Do not bend or puncture the battery.
  6. LG K30 Screen Replacement, Motherboard: stap 6, afbeelding 1 van 1
    • Use a spudger to carefully disconnect the front camera connector.
    • Use a spudger to disconnect the display cable connector.
  7. LG K30 Screen Replacement: stap 7, afbeelding 1 van 2 LG K30 Screen Replacement: stap 7, afbeelding 2 van 2
    • Remove the motherboard assembly from the display assembly with the a spudger or hand.
  8. LG K30 Screen Replacement, Screen: stap 8, afbeelding 1 van 3 LG K30 Screen Replacement, Screen: stap 8, afbeelding 2 van 3 LG K30 Screen Replacement, Screen: stap 8, afbeelding 3 van 3
    • Gently pry out front-facing camera with plastic spudger.
    • Re-assemble with replacement screen/frame.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Alisha Lee
277 Reputatie
3 handleidingen geschreven
3 opmerkingen
I just need to replace the front glass on the screen, not the entire screen. Will this guide work to do that?
Kai B - Antwoord
Don't think so. This one just replaces everything with the frame. I watched a few other vids on YT on display replacement though, and some involved crushing the glass on the broken display along with the display itself to remove it from the frame, so I can assume it's very difficult to keep the display intact while removing the glass.
E. V. -
When doing this repair, don't forget about all the rubber grommets and stuff. Especially the one by the proximity sensor where the sensor sits. If you do not have this rubber piece, the screen will turn off during phone calls.
Richard D - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 6
Altijd: 4,575
