Inleiding
This guide will show you how to replace the screen touch digitizer display with frame for LG K30.
Make sure that when prying the front-facing camera off of the frame, use caution so as not to cause any damage to the connecting points or to the frame.
Wat je nodig hebt
Power off your Phone before beginning disassembly.
Use the 'Jimmy' and 'Metal Spudger' to slowly pry open the outsides of the back case.
Use a spudger to carefully disconnect the front camera connector.
Use a spudger to disconnect the display cable connector.
Gently pry out front-facing camera with plastic spudger.
Re-assemble with replacement screen/frame.
6 andere personen hebben deze handleiding voltooid.
3Gids Commentaar
I just need to replace the front glass on the screen, not the entire screen. Will this guide work to do that?
Don't think so. This one just replaces everything with the frame. I watched a few other vids on YT on display replacement though, and some involved crushing the glass on the broken display along with the display itself to remove it from the frame, so I can assume it's very difficult to keep the display intact while removing the glass.
