Ga door naar hoofdinhoud
LG K30 Motherboard Replacement
Wat je nodig hebt
  1. LG K30 Motherboard Replacement, Battery: stap 1, afbeelding 1 van 2 LG K30 Motherboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • Before disassembling your LG K30, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your Phone before beginning disassembly.
    • Use the 'Jimmy' and 'Metal Spudger' to slowly pry open the outsides of the back case.
  2. LG K30 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the thirteen 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
  3. LG K30 Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Use a metal spudger or plastic opening tool to pry open the outer cover.
  4. LG K30 Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Use the flat end of a spudger to detach the battery connector from the logic board.
  5. LG K30 Motherboard Replacement: stap 5, afbeelding 1 van 2 LG K30 Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Use a spudger to pry the battery from the phone.
    • There may be an adhesive on the back of the battery and the phone. Pry the battery gently to prevent puncture or damage.
    • Do not bend or puncture the battery.
  6. LG K30 Motherboard Replacement, Motherboard: stap 6, afbeelding 1 van 1
    • Use a spudger to carefully disconnect the front camera connector.
    • Use a spudger to disconnect the display cable connector.
  7. LG K30 Motherboard Replacement: stap 7, afbeelding 1 van 2 LG K30 Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Remove the motherboard assembly from the display assembly with the a spudger or hand.
Conclusie
4 andere personen hebben deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 16
Altijd: 1,983
