Ga door naar hoofdinhoud
LG K20 PLUS Motherboard Removal
Wat je nodig hebt
  1. LG K20 PLUS Motherboard Removal, Remove the back cover and battery: stap 1, afbeelding 1 van 2 LG K20 PLUS Motherboard Removal, Remove the back cover and battery: stap 1, afbeelding 2 van 2
    • Remove the back cover by inserting a fingernail or opening pick here and disengaging the plastic clips.
    • Lift battery up here
  2. Voorzichtig: stappen 2-3 komen van een handleiding die in bewerking is.
    LG K20 PLUS Motherboard Removal, Midframe: stap 2, afbeelding 1 van 1
    • Remove 11 Philips screws.
  3. LG K20 PLUS Motherboard Removal: stap 3, afbeelding 1 van 2 LG K20 PLUS Motherboard Removal: stap 3, afbeelding 2 van 2
    • Use fingernails or insert an opening pick into the gap between the digitizer and the midframe and pull the midframe outwards to disengage the plastic clips.
    • Carefully disengage the clips on the bottom as the headphone jack goes through the midframe.
    • Once all the clips have been disengaged, move the midframe outwards and downwards to disengage it from the headphone jack.
  4. LG K20 PLUS Motherboard Removal, Rear-Facing Camera: stap 4, afbeelding 1 van 1
    • Use a Halberd spudger or an opening pick to disconnect the front camera flex from its connector on the motherboard.
  5. LG K20 PLUS Motherboard Removal, Motherboard Removal: stap 5, afbeelding 1 van 1
    • Using the tip of a Halberd spudger or an opening pick, disconnect the display flex cable from its socket on the motherboard.
    • Starting from the bottom, insert an opening pick between the motherboard and frame and lever apart.
    • Be careful not to break the long section of the motherboard.
    • The top part of the motherboard is lightly adhered to the frame.
    • After the motherboard is removed, compare the original and replacement part. Some components may already be installed on the replacement display assembly.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Patrick
6.574 Reputatie
21 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 676
