Ga door naar hoofdinhoud
Onderdelen
Geen onderdelen opgegeven.
  1. Remove the back cover by inserting a fingernail or opening pick here and disengaging the plastic clips. Lift battery up here
    • Remove the back cover by inserting a fingernail or opening pick here and disengaging the plastic clips.
    • Lift battery up here
  2. Remove 11 Philips screws.
    • Remove 11 Philips screws.
  3. Use fingernails or insert an opening pick into the gap between the digitizer and the midframe and pull the midframe outwards to disengage the plastic clips. Carefully disengage the clips on the bottom as the headphone jack goes through the midframe.
    • Use fingernails or insert an opening pick into the gap between the digitizer and the midframe and pull the midframe outwards to disengage the plastic clips.
    • Carefully disengage the clips on the bottom as the headphone jack goes through the midframe.
    • Once all the clips have been disengaged, move the midframe outwards and downwards to disengage it from the headphone jack.
Conclusie
Patrick
5.564 Reputatie
18 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 34
