Ga door naar hoofdinhoud
LG K20 PLUS Midframe Replacement
Wat je nodig hebt
  1. LG K20 PLUS Midframe Replacement, Remove the back cover and battery: stap 1, afbeelding 1 van 2 LG K20 PLUS Midframe Replacement, Remove the back cover and battery: stap 1, afbeelding 2 van 2
    • Remove the back cover by inserting a fingernail or opening pick here and disengaging the plastic clips.
    • Lift battery up here
  2. LG K20 PLUS Midframe Replacement, Midframe: stap 2, afbeelding 1 van 1
    • Remove 11 Philips screws.
  3. LG K20 PLUS Midframe Replacement: stap 3, afbeelding 1 van 2 LG K20 PLUS Midframe Replacement: stap 3, afbeelding 2 van 2
    • Use fingernails or insert an opening pick into the gap between the digitizer and the midframe and pull the midframe outwards to disengage the plastic clips.
    • Carefully disengage the clips on the bottom as the headphone jack goes through the midframe.
    • Once all the clips have been disengaged, move the midframe outwards and downwards to disengage it from the headphone jack.
Conclusie
Patrick
6.776 Reputatie
21 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 20
Altijd: 212
