Ga door naar hoofdinhoud
LG K10 Rear Camera Replacement
Wat je nodig hebt
Video overzicht
  1. LG K10 Rear Camera Replacement, Rear Camera: stap 1, afbeelding 1 van 1
    • Power off the device
    • Remove the backing
  2. LG K10 Rear Camera Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery
  3. LG K10 Rear Camera Replacement: stap 3, afbeelding 1 van 1
    • Unscrew every screw of the bottom of the phone and use guitar picks to remove the plastic frame of the phone
  4. LG K10 Rear Camera Replacement: stap 4, afbeelding 1 van 1
    • With a pick lift the side of the phone, in order to remove the backside
    • Repeat this step on all sides of the phone
  5. LG K10 Rear Camera Replacement: stap 5, afbeelding 1 van 1
    • Once the back is completely off, you now have complete access to the rear camera
    • You also now have access to the rear/ front speakers, and motherboard
  6. LG K10 Rear Camera Replacement: stap 6, afbeelding 1 van 1
    • Insert a plastic opening tool under the edge of the rear camera's press-fit connector. Lift the connector up and away from the motherboard to pop the ribbon cable free.
    • Remove the rear facing camera.
Conclusie
Witrigs
70.190 Reputatie
377 handleidingen geschreven
Één opmerking
Can you upgrade the original camera with say a G5 camera?
Larry Smith - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 14
Altijd: 1,672
