Ga door naar hoofdinhoud
LG Intuition Volume Buttons Replacement
Wat je nodig hebt
  1. LG Intuition Volume Buttons Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the device so the two bottom screws are shown.
  2. LG Intuition Volume Buttons Replacement: stap 2, afbeelding 1 van 1
    • Remove the two 7mm screws holding the back panel of the phone using the P5 bit and magnetic driver.
  3. LG Intuition Volume Buttons Replacement: stap 3, afbeelding 1 van 1
    • Carefully use the plastic opening tool to pry the back panel of the phone from the front screen. This will expose the battery and other parts.
  4. LG Intuition Volume Buttons Replacement: stap 4, afbeelding 1 van 1
    • Use the Phillips #0 screwdriver to remove the 5mm screw holding the metal bracket that protects the battery's ribbon cable.
  5. LG Intuition Volume Buttons Replacement: stap 5, afbeelding 1 van 1
    • Carefully use the plastic opening tool to pry the ribbon cable connecting the battery to the motherboard of the phone.
  6. LG Intuition Volume Buttons Replacement: stap 6, afbeelding 1 van 2 LG Intuition Volume Buttons Replacement: stap 6, afbeelding 2 van 2
    • Gently raise the battery from its compartment.
  7. LG Intuition Volume Buttons Replacement, Plastic Motherboard Shield: stap 7, afbeelding 1 van 1
    • Remove the thirteen 5mm screws holding the plastic shield covering the motherboard using the Phillips #00 screwdriver.
  8. LG Intuition Volume Buttons Replacement: stap 8, afbeelding 1 van 1
    • Carefully use the plastic opening tool to pry the plastic shield from the motherboard. This will expose the motherboard and ribbon cables for each component.
  9. LG Intuition Volume Buttons Replacement, Volume Buttons: stap 9, afbeelding 1 van 2 LG Intuition Volume Buttons Replacement, Volume Buttons: stap 9, afbeelding 2 van 2
    • Slowly pull the ribbon cable upward releasing the volume buttons from the phone.
Conclusie
Thomas Morrissey
616 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team S3-G4, Peak Fall 2018 Lid van UMass Dartmouth, Team S3-G4, Peak Fall 2018
UMASSD-PEAK-F18S3G4
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 4
Altijd: 123
