Inleiding
If your camera fails or will not turn on, use this guide to replace your camera.
Wat je nodig hebt
Remove the thirteen 5mm screws holding the plastic shield covering the motherboard using the Phillips #00 screwdriver.
Carefully use the plastic opening tool to pry the ribbon cable below the camera itself from the motherboard.
Bijna klaar!
Conclusie
