Ga door naar hoofdinhoud
LG Grace Prerequisite Dissasembly
Wat je nodig hebt
  1. LG Grace Prerequisite Dissasembly, Phone Assembly: stap 1, afbeelding 1 van 1
    • Find the indentation along the edge of the phone's back and pry open with your nail. A pry tool may help if you have short nails but shouldn't be necessary.
  2. LG Grace Prerequisite Dissasembly: stap 2, afbeelding 1 van 1
    • Pull the battery out of the back of the phone. A small indent is present to allow you to pry it out but you may also just flip the phone over and strike it gently against your palm.
  3. LG Grace Prerequisite Dissasembly: stap 3, afbeelding 1 van 2 LG Grace Prerequisite Dissasembly: stap 3, afbeelding 2 van 2
    • Unscrew all of the screws now visible on the back panel of the phone--11 in total. A #00 Phillips screwdriver works here.
    • The screws are M1.3 and 3 mm long.
  4. LG Grace Prerequisite Dissasembly: stap 4, afbeelding 1 van 2 LG Grace Prerequisite Dissasembly: stap 4, afbeelding 2 van 2
    • Insert the Jimmy into the small gap between the edge of the phone screen and body. Gently pry until it pops loose then remove jimmy and use your hands to slowly pry the body away from the screen
Conclusie
Dylan Kent
679 Reputatie
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 47
