Ga door naar hoofdinhoud
LG G6 SIM Card Reader Replacement
Wat je nodig hebt
    • Insert wisdom here.
Conclusie
MovilOne
2.480 Reputatie
14 handleidingen geschreven
3 opmerkingen
Nice Work. Instead of using the iron to solder it to the board, could you use a heat gun instead?
B Thomp - Antwoord
Yes, use leaded solder and small amount of no clean flux, maximum heat of 250 c, as described my Molex datasheets and part will self align
Greg Hamilton - Antwoord
We have repaired many of these LG G6 phones with damage to the sim card reader, it looks like it is a very common issue with this phone. The sim card tray gets stuck or jammed inside the reader, and when force is applied to pull the tray out, it ends up damaging the pins for the sim card or memory card reader. It is easily repaired though if you have the correct tools and skills!
smartfonefix - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 4,302
