Ga door naar hoofdinhoud
LG G5 Battery Replacement
Wat je nodig hebt
  1. LG G5 Battery Replacement, Battery: stap 1, afbeelding 1 van 3 LG G5 Battery Replacement, Battery: stap 1, afbeelding 2 van 3 LG G5 Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Power down the phone by holding the power button for several seconds.
    • While holding the battery release button, pull the bottom end of the phone out of the body.
  2. LG G5 Battery Replacement: stap 2, afbeelding 1 van 2 LG G5 Battery Replacement: stap 2, afbeelding 2 van 2
    • Separate the battery from bottom half.
    • Insert the new battery in the same position and orientation as the old battery. Match up the arrows to be sure the orientation is correct.
Conclusie
22 andere personen hebben deze handleiding voltooid.
Sam Goldheart
471.874 Reputatie
538 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.643 handleidingen geschreven
4Gids Commentaar
Success. Excellent guide, thank you.
Cheers,
Richard.
rmgs - Antwoord
Was machen wenn Akku Snap In ab ist?
Ra Ku - Antwoord
Hallo, was machen wenn Snap In vom Akku ab ist und Akku im Gehäuse fest sitzt?
Ra Ku - Antwoord
Absolutely great instructions. The battery I got for replacement comes uncharged (probably new shipping laws) so you might put in “Battery needs to be calibrated by fulling charging new battery to 100% then letting battery COMPLETELY run down to 0% before returning to normal use and charging.”
Michael Aarons - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 75
Altijd: 16,271
