Wat je nodig hebt
While holding the battery release button, pull the bottom end of the phone out of the body.
Insert the plastic opening tool into the seam between the glass screen and the metal body.
Pry the glass from the body only a slight amount.
It is, i can’t seem to do it too easily either. Maybe i need to heat it up? I don’t want to damage it as it will still be used as a camera.
Insert the Spudger into the now open space between the body and screen.
Push inward to separate the screen even more.
Slowly slide the nylon spudger up the edge the phone till the screen pops out of the body.
My LCD started to let loose using this way to saparate the top and bottom of the phone.
I used a guitar pick and slided it from the bottom to the top like the dude in this video: https://www.youtube.com/watch?v=XV10zyw8...
Didn’t had to use a lot of force this way, and my screen almost didn’t bend !
Yep! I did it also with this method. Wayy better and easier ;)
I found it easier to run the tool or a pick along the sides, and then sort of hinge the thing open at the top rather than running completely around the screen. It gets a little dicey where the glass starts to curve.
Locate the auxiliary port on the top right of the phone
Using a finger, carefully take the port out
8 andere personen hebben deze handleiding voltooid.
2 opmerkingen
I saw a video where someone used a guitar pick as the plastic opening tool, seems safer to me. And that person also had a great idea to shove a pencil in the battery bay to apply a separating force, so that as you work the seam with a guitar pick, the the two halves will naturally want to separate.
Hi, I have two LG G5 phone. Let's call them
A & B.
So , B overheats and the battery last less than an hour. So I took the battery from A and I put it in B and I put the B battery in the A. Results: B still overheats and not the A ??? I also left the connector blocks on the batteries when I did the switching. So what could be the cause of this?
